BrooklynOrbi
Dec 11, 2018Aspirant
Satellite Placement and Adding Extender
I live in a narrow but fairly deep 4 story brownstone house. My cable service and modem are in the front room on the third floor, which is where the Orbi router now lives. I did not find much success...
BrooklynOrbi
Firmware is up to date.
Modem: ARRIS SURFboard SB6183 Modem 16x4 Docsis 3.0
Overall square footage is around 3000 (800+ per floor)
Distance between router and satellite is around 30 feet.
Dec 11, 2018Guru - Experienced User
If you can maintain 30 feet distance between router and satellit(s), adding another if you see a need in remote locations where you don't get much or very lilttle wifi signal, shouldn't be a problem. Others have posted that they have added up to 6 satellites. Kind of extreme though. Works for them.
- DickDukeDec 12, 2018Apprentice
You can try adding an Ethernet over powerline adapter to go to another floor. The Orbi satellite can then use that for its backhaul (connection to the router)
https://www.netgear.com/home/products/networking/powerline/PLP2000.aspx
