MikeNG99
Aug 21, 2020Aspirant
Satellite (RBR20) Loses Connection - No Light Indicating any Issue
Hello, For the past couple of months my satellite has been losing connection to the router once every couple of days (2nd time today though!) and there is no light on the satellite indicating any...
- Aug 29, 2020
MikeNG99 wrote:I paper clip reset the Satellite last Sunday and have not had a disconnect between router and satellite since (6 days).
Great news!
Most of the time rebooting and resetting these devices eliminates the problems, that users are having, caused by the Orbi. Unfortunately they are so tired of hearing the suggestion ovrer and over, that they stay frustrated a lot longer than it takes to just do a Reboot or Factory Reset.
kevin05
I have similar issue. The connect dropped frequently. I noticed that it happened after the installation of firmware v2.5.1.16. Is there anyway to go back the previous version?
Mstrbig
Aug 21, 2020Master
kevin05 wrote:I have similar issue. The connect dropped frequently. I noticed that it happened after the installation of firmware v2.5.1.16. Is there anyway to go back the previous version?
After you upgraded to 2.5.1.16 did you reboot your system? If you have satellites, dod they upgrade as well?
I have many many systems running on 2.1.1.15 with no issues. Most all of them upgraded from the previous firmware. After firmware update, I only had to reboot the systems.
