orbira
Oct 21, 2019Apprentice
Satellite RBR50 dead after firmware upgrade 2.5.0.38
Hi, Today I upgraded to Orbi firmware 2.5.0.38. The router and one satellite came back up fine. 2nd satellite would not power on now. I have tried resetting, removing power etc., bout no lights, se...
- Oct 21, 2019
Check the power adapter that plugs into the RBS.
Swap power adapters with the one that works for the other RBS.
Oct 21, 2019Guru - Experienced User
Does it do anything? Is the power light on the back lit up?
If so you could try using tftp to do so.
Here's a thread that talks about recoving it with tftp.
https://community.netgear.com/t5/Orbi/Orbi-Satellite-corrupt-firmware/m-p/1636597
And the tftp utility instructions
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp from within windows.
https://www.thewindowsclub.com/enable-tftp-windows-10
