Orbinate
Oct 25, 2018Aspirant
Satellite (RBS50) Does Not Broadcast 5GHz
I have the AC3000 system: One RBR50 (Router) and one RBS 50 (Satellite).
The 5GHz backhaul connecting the satellite to the router is working fine.
The problem that I seem to be having is ...
ekhalil
Oct 26, 2018Master
Orbinate wrote:
Instead, they all connect to the router, using the 5GHz band, even though the router is farther away from where the satellite is relative to those devices.
I used a WiFi scanner software to see what WiFi signals look like in my house and in the area.
I noticed two 5GHz sources and 2.4 GHz sources.
If you see two 5GHz networks and two 2.4GHz networks then -most probably- both Router and Satellite are transmitting correctly.
It can be that you have much noise in the area that you have the Satellite on the radio channel that you are using. I would suggest you to try other 5 GHz channels one by one until you get your devices to connect to the correct (nearest) point.
