anouschkaw
May 01, 2021Aspirant
satellite RBS50 flashing white need to update firmware
The firmware on this satelite is different from the router's firmware and the other (working) satellite. I've tried resetting, syncing, unplugging, everything. How do I manually get this satelli...
May 04, 2021Guru - Experienced User
Manual RBS FW update after RBR was updated:
You need to update the RBS before updating the RBR. Keep this in mind for future updates.
What you need to do is factory reset the RBS. Wire connect a PC to the 1st satellite. Already have the most current FW version files downloaded on to this PC.
Wire connect 1 PC to the back of the RBS. Factory reset the RBS, wait about 5 minutes. The PC will get a IP address from the satellite. The RBS will be 192.168.1.250. Use this IP address in a web browser to log in to the satellites web page. Log in as admin and password. Use the satellites web page FW update feature to select the FW update file that was unpacked from the .zip file. Then factory reset and then re-sync the satellites to the RBR.
