Augusto_meltin
Dec 05, 2018Aspirant
Satellite RBS50 non su connette a router RBR50
Buongiorno a tutti,
ho un problema con il secondo satellite RBS50, che si connette ma non si sincronizza con il router RBR50.
Alla prima installazione funziona tutto, ma quando metto il r...
randomousity
Dec 08, 2018Luminary
Try placing the satellite right next to the router and sync them again. I had a similar issue the other day, and it failed on the first attempt, but then succeeded on the second attempt. Then I put the satellite back in its usual location and it worked fine.
If that doesn't work, try going into the router settings and having it generate a new secure backhaul password (advanced > advanced setup > wireless settings > generate), and/or try a factory reset on the satellite (insert a paper clip into the tiny hole on the back side). I performed all those steps, but I don't know that the new password and factory resetting are necessary, so you can try skipping those and see how it works for you.
May the odds be ever in your favor.
