vadhopper
Apr 25, 2023Aspirant
Satellite RBS50 will not reset - not responsive
I have a Satellite that stopped connecting to the network. I have removed it from the network and tried to reset it with a pin, and while I feel the reset depress, no amber light comes on. Nothing ...
Apr 26, 2023Guru - Experienced User
How long did you press the reset button for? 15 seconds is recommended.
Might try a 30-30-30 reset to see if this helps...if not, the RBS maybe busted.
