Retired_Member
Nov 28, 2017Satellite Re-synch
If I move one of my Orbi AC3000 satellites (there are 2), do I have to perform a manual re-synch?
The manual states that the router and satellites will automatically synch and I believe that’s what happened during initial setup.
However, the manual goes on to say you can do a manual re-synch by pressing the buttons on the router/satellite.
1 Reply
Sort By
- Retired_Member
I believe for now I'll leave both sats where they are. They are both connected and appear to be working. One sat is about 50' from the router and the other is about 30' from the router. What's interesting is that the one that is at the 50' range is bearing the heaviest load with most of my devices connected there.
