Thomas-EQTR
Mar 17, 2021Aspirant
Satellite Recommendation
I can't even find it on the model drop down lol I'm looking for Satalite recommendation for an RBK40 system, I only need a satellite the will work with this mesh please. Kind Regards, Thomas...
vajim
Mar 17, 2021Master
Thomas-EQTR wrote:I can't even find it on the model drop down lol
Kind Regards,
Thomas
Every model of Orbi satellite is compatible with every Orbi router.
- CrimpOnMar 17, 2021Guru - Experienced User
vajim wrote:
Every model of Orbi satellite is compatible with every Orbi router.I think that is almost correct. Only Orbi AC satellites from the residential product line are compatible (not "Pro", not "AX") except for the RBS10, which is a "dual band" product rather than a "tri band" product. This is frustrating because the RBS10 is the least expensive satellite that is readily available now that Amazon has raised the price on the RBS40V from $100 to $160.
- vajimMar 17, 2021Master
CrimpOn wrote:
Thanks for the clarification
