Dazza762
Feb 11, 2022Luminary
Satellite region blank
When I log into either of the satellites in my RBK753 system, the wifi regions for 2.4 and 5 are blank. Is there a way to set this? Previously one of them was set to Europe but both are now blank.
Feb 11, 2022Guru - Experienced User
What browser are you using?
NG may have removed that option in recent FW updates.
Can you attached a screen shot of what your seeing on the RBS?
Are you having any problems with the RBS?
- Dazza762Feb 11, 2022Luminary
FURRYe38 wrote:What Firmware version is currently loaded?
Hardware Version: RBS750
Orbi Satellite WiFi Status (2.4GHz)
Name (SSID) XXXXX
Channel : 3(P)+7(S)
Region:-
Wireless mode : Up to 573 Mbps
Wirless AP : On
Broadcast Name: On
Security type : WPA2-PSK
Firmware Version : V4.6.5.14
Orbi Satellite WiFi Status (5GHz)
Name (SSID)
Channel: 36+40(P)+44+48
Region:-
Wireless mode: Up to 1201 Mbps
Wirless AP : On
Broadcast Name: On
Security type: WPA2-PSK - FURRYe38Feb 12, 2022Guru - Experienced User
Is there a language select menu near Orbi Statellite text upper right hand corner of this screen?
Region won't be displayed on Orbi AX systems.
Netgear has set up a community forum specifically for the Orbi AX products. Most of the people who watch that forum are more likely to have experience with Orbi AX (WiFi6 RBK 3,7,8 and 9 Series) products:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you.
