Dazza762
Feb 11, 2022Luminary
Satellite region blank
When I log into either of the satellites in my RBK753 system, the wifi regions for 2.4 and 5 are blank. Is there a way to set this? Previously one of them was set to Europe but both are now blank.
Feb 11, 2022Guru - Experienced User
What browser are you using?
NG may have removed that option in recent FW updates.
Can you attached a screen shot of what your seeing on the RBS?
Are you having any problems with the RBS?
- FURRYe38Feb 12, 2022Guru - Experienced User
Is there a language select menu near Orbi Statellite text upper right hand corner of this screen?
Region won't be displayed on Orbi AX systems.
Netgear has set up a community forum specifically for the Orbi AX products. Most of the people who watch that forum are more likely to have experience with Orbi AX (WiFi6 RBK 3,7,8 and 9 Series) products:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you.
