OlivierAlsace
Dec 30, 2020Aspirant
Satellite showing as disconnected on Web app but as Connected on iOS and is working normall
Hi, I have a RBK20 + 2 RBS20 (Basement and 1st Floor). Originally both satellites were connected in wifi and it was all good. For a few weeks I have the following issue after having connect 1...
Dec 30, 2020Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Is Daisy Chain enabled? If it is, try disabling it. I'd power cycle the RBS as well after the RBR reboots.
OlivierAlsace
I disabled the Daisy Chain and all is back to normal.
THANKS
- FURRYe38Dec 31, 2020Guru - Experienced User
Glad that workied. Please mark your thread as solved so others will knowl.
Enjoy. :smileywink:
