th3w01f
Sep 23, 2016Apprentice
Satellite showing up as a device and not a satellite.
Setting up my new Orbi and while it shows that there are devices and one satellite connect, when I drill down the satellite shows with the rest of the devices and the section under satellites is bla...
th3w01f
While I was driving, support called about my initial link issue and I asked about a way to see the link quality between the router and satellite. I was told that there was a backhaul status page that would show the link quality but I can't seem to find it. Any ideas?
They said to go under Router -> Status -> Backhaul.... but I don't see any of that.
btotheeck
Sep 23, 2016Initiate
While I dont see a link quality per-se, I do see a backhaul statistic row in the "Show Statistics" button popup which is found on the Advanced Home page, or http://192.168.1.1/RST_statistic.htm
Look at the bottom row. I suspect the "Status" column is not really indiciative of the actual link strength, just the possible bandwidth or something along those lines.
For comparison purposes, mine says my WLAN Backhaul is 1733M.
- th3w01fSep 23, 2016Apprentice
Good catch, I didn't even notice that. Mine shows 1733 as well, I'll have to move it around and see if it changes.
