toddinpal
Aug 14, 2020Aspirant
Satellite showing up as connected device, unknown connection type
So I'm trying to set up a new RBR50/RBS50. After being set up, they needed a firmware update (don't recall from version or to version), and from then on the satellite couldn't connect. I upgraded a...
toddinpal
Been there, done that, multiple times.
Mstrbig
Aug 14, 2020Master
Did you try this on the satellite, as they tend to be stubborn sometimes?
Turn off satellite, hold down the reset button, power up the satellite while holding down the reset, do not let go of the reset until you see the power light turns red, then let go.
- toddinpalAug 15, 2020Aspirant
Yes, I tried that form of reset. As I mentioned before I also tried a 30-30-30 reset. I'll try several more times, but this seems a bit absurd.
-tl
