sregiaco
Dec 20, 2022Follower
Satellite slower with fiber
I have and Orbi Mesh AC300 (RBK50) with a satellite. My computer is about 20 ft way from the satellite with a brick fireplace/wall in between. Until yesterday we had decent speed from the satellite. ...
CrimpOn
Dec 20, 2022Guru - Experienced User
WiFi signal levels are a function only of the WiFi units. Assuming the new fiber connection provides at least as much speed as the previous Xfinity connection, that change should have no effect on WiFi.
WiFi is really sensitive to building materials. Moving the router and/or satellite only a few feet can sometimes make a dramatic difference in signal level. Was anything 'moved' during the change from Xfinity to i3?
What sort of device did i3 install? Is it:
- A simple Optical Network Terminal (ONT - https://en.wikipedia.org/wiki/Network_interface_device#Optical_network_terminals )?
- A combination ONT/router/ perhaps WiFi?
