Edgar_dc
Aug 06, 2018Initiate
Satellite starts DoS Attack: ARP Attack when connected to Ethernet
Router Firmware Version V2.1.4.16
Last night the internet access when down. After looking for a cause, I found that as soon as the satellite is conected to ethernet it starts an "ARP attack". Samp...
- Sep 30, 2018Unplugging the TPLink switches while connecting the satellites worked! After verifying the network was happy I plugged the switches back in and everything works.
Thanks for the help!
Sep 30, 2018Guru - Experienced User
Ok, let us know how it goes. Wondering about your switches. Hopefully it will all work out.
RatChickens wrote:
The orbi satellite is connected through Netgear switch, but for some reason unplugging the TP-Link switches, setting up the satellite and then plugging the switches back in worked. Now I have Ethernet backhaul working on one satellite. I’ll try this process later on the other one.
RatChickens
Sep 30, 2018Tutor
- FURRYe38Sep 30, 2018Guru - Experienced User
Ok, Some switchay may need that as to update there MAC address table.
Enjoy.
