Edgar_dc
Aug 06, 2018Initiate
Satellite starts DoS Attack: ARP Attack when connected to Ethernet
Router Firmware Version V2.1.4.16
Last night the internet access when down. After looking for a cause, I found that as soon as the satellite is conected to ethernet it starts an "ARP attack". Samp...
- Sep 30, 2018Unplugging the TPLink switches while connecting the satellites worked! After verifying the network was happy I plugged the switches back in and everything works.
Thanks for the help!
Edgar_dc
Oct 06, 2018Initiate
**Update:
Updated to the new firmware V2.2.1.210 and it is working ok for a couple of days now. Also, after updating and testing them (Router and Sat), I plugged my NetGear ProSafe GS108E and disable IGMP on it (saw a recommendation on the thread). I also have a Disney Circle, Synology NAS, Xbox, etc.
We will see how it goes...
Oct 06, 2018Guru - Experienced User
Hope it works better for you. :smileywink:
