merrick777
Feb 01, 2020Aspirant
Satellite sync light indicator issue
RBR50 and satellite RBS50. I think the satellite is connected properly to network because I can see both the router and the satellite in the Network map in the Orbi app. However I am definitely havin...
Feb 01, 2020Guru - Experienced User
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
