Will_T
Dec 02, 2020Apprentice
Satellite Update Question
I see many posts telling people to always update their satellites first, then the main router. However whenever I see updates, it just says to update the satellites first. However the only button i...
- Dec 02, 2020
Will_T wrote:Sorry, I guess I was not specific enough in my question. My RBS webpage already does show the firmware downloaded and ready for the two satellites and for the main router. There is only one option to update however - the button that says "Update All". There is no way of knowing what will happen when clicking that button. Will it apply the satellite updates first as so many here say to do? Then apply the router update? How can I be sure to apply the satellite update first?
There are two ways to update firmware on the Orbi:
- Click the "Update" button and let the Orbi do it however it does it, or
- Download the actual image files from the Netgear support site, unpack to extract the ".img" files, then
* Connect to each satellite home page (by IP address) and click on "Firmware Update", then
* Connect to the router web management, navigate to the Firmware Update page, and click on the "Manual Update" tab.
Following method 2 is (a) MUCH less convenient than letting the Orbi "do its thing", and (b) gives the user total control over which firmware is updated on which Orbi.
Will_T
vajim
Dec 02, 2020Master
Update all works.
- Will_TDec 02, 2020Apprentice
vajim wrote:Update all works.
Are you saying that "update all" works because you did it that way and had no problems? Or are you saying that doing it that way definitly updates the satellites first and then the router? Thanks.
- vajimDec 02, 2020Master
I'm saying from someone who doesn't update every weekend. I took a deep breath and clicked update all basically trusting NG to update their gear. And guess what? It worked. Might try it again next year.
- FURRYe38Dec 02, 2020Guru - Experienced User
Amazing
ive always wondered how that works
