Grouper5
Dec 23, 2017Initiate
Satellite waiting for connection
I want to update the firmware of my system but on the Netgear login page it says that the satellite is waiting for a connection. The satellite is performing fine. What do I do to update the firmware ...
Whirlyblades
Dec 24, 2017Tutor
I am having the same issue. I'm also have conectivity issues. I have rebooted them probably 10 times. They'll work for a little while, then I have no internet connection and I get a solid magenta ring. I work from home and they have been stable for over a year. There is something going on for sure! Firmware is V2.1.1.16
- WhirlybladesDec 24, 2017Tutor
Ok, messed around with it and i discovered this.
My sattelite was showing disconnected so I deleted it from the list, Advanced\Administration\Attached Devices, and then resync'ed it. I'll post back if i still have issues, otherewise, figure everything is now fine!
