ReegoAspirantJan 21, 2021satellite will not connect RBK50 satellite will not connect , blinks white then just stops ? Help , worked for 1 day now will not connect ?
vajimMaster to ReegoJan 21, 2021Reego wrote:yes white just goes away stops blinking on bothif the white goes away, that means you're good to go... what makes you think the sat is NOT connected or connecting? I hope you're not using the app, if so, try logging in at the web using the login there.
