Reego
Jan 21, 2021Aspirant
satellite will not connect
RBK50 satellite will not connect , blinks white then just stops ? Help , worked for 1 day now will not connect ?
Jan 22, 2021Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
Reego wrote:RBK50 satellite will not connect , blinks white then just stops ? Help , worked for 1 day now will not connect ?
vajim
Jan 22, 2021Master
FURRYe38 wrote:What is the size of your home? Sq Ft?
He's still checking out the lights
Thanks anyway
