ggal625
Jul 02, 2018Aspirant
Satellite wireless backhaul stopped working
RBK50 purchased and installed back in April. Manually updated both router and firmware to firmware 2.1.4.10.
Working fine until 3PM last Saturday. Devices connected to satellite do not get a DHCP a...
Jul 02, 2018Guru - Experienced User
Did you only set up 1 satellite?
You should have two satellites in your kit, if you do, and didn't set up the other satellite, try setting it up and see if the 2nd satellite does same thing or not.
Possible you have a bad satellite.
Turn off all satellites and make sure your devices connect ok to the main router base.
