mgonzalezpr
Jun 21, 2021Aspirant
Satellite with blinking red light cannot be found by router, doesn't reset or sync either.
I have a Orbi (RBR10) Router with 2 satellites (RBS10). One satellite is working fine, the other simply does not sync anymore (worked when I first set up the system). It shows a pulsating red light ...
mgonzalezpr
FURRYe38 Thank you! I have a question before I attempt that... The problem I am having is with just one of the satellites, but the instructions always refer to the router... I just need to confirm, that even if the problem is with one of the satellites (I have 2, the other is working fine) I need to work on/with/through the router.
Jun 21, 2021Guru - Experienced User
Apply those instructions to the RBS. You'll be working on the one effected RBS with a wired PC to see if you can get it recovered.
