JoshBear
Nov 03, 2018Aspirant
Satellite won’t connect
Hi all I bought a started pack of main and satellite rbk50 back in April. Since then I have added two additional satellites. Yesterday we noticed the original satellite that came with the router we...
randomousity
Nov 03, 2018Luminary
Have you tried the sync button on both the satellite and the router? I've had issues where the satellite lost its connection to the router, and uplugging them both and then plugging them both in again resolved the issue and they connected again, as expected.
If none of that works, you can try connecting to the satellite via ethernet, and then go to the satellite's configuration page and you may be able to reset it that way (this may require using a static IP on the computer, or at least determining the auto-configuration IP addresses of both the cmoputer and the router). I have also heard that if the router and satellite are on different firmware versions, this can cause issues. You could check the firmware versions, and see if you can manually update the satellite's firmware if the versions are mismatched.
- JoshBearNov 03, 2018Aspirant
Thanks for the help. Will try the Ethernet connection idea. Have tried the syncing buttons on both and the switching off and on of both router and satellite.
- randomousityNov 03, 2018Luminary
You can also try logging into the router and going to Advanced > Advanced Setup > Wireless Settings and using the "Backhaul Password" option. This should cause the router to generate a new, random, password, after which you might have to sync **all** your satellites, but that might resolve the issue for you.
It also occurred to me you might want to check the "Enable Daisy-Chain Topology" option on the same page, as it could be that it's disabled and your original satellite is attempting to connect to one of the newer satellites, rather than directly to the router, due to range or placement issues, but that you have this ability disabled. It's possible that enabling daisy chaining could help you.
Finally, you could also try using the setup wizard, and trying to re-add the missing satellite that way. I believe at some point in the setup process, it will ask if you want to add a satellite, and it might either add them all for you at once, or allow you to keep adding individual ones until they're all added.
If none of those ideas from either this post or my previous one work, then you can either try a factory reset on the entire Orbi system, or using a wired backhaul to the lapsed satellite. If none of those work, then I'm out of ideas.
- JoshBearNov 04, 2018AspirantHi
Connected the satellite to the router via Ethernet. When to orbilogin page but it doesn’t show up. Used the add orbi satellite button on the web but it waited three mins then Sao satellite set up failed.
Checked advanced settings for the network. Daisy chain is on. So is implicit beamforming.
Any ideas? Thanks- FURRYe38Nov 04, 2018Guru - Experienced User
What FW is currently loaded?
What is the Mfr and model# of the ethernet switch if one is in the configuration.Try disabling the following and see:
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually. Hoping NG support can have a look at this. So try this out as well.
Set up IP address reservations for each satellite and devices on the router as you add them to the router. The satellites need to be set up via wireless first. Then connect 1 satellite at a time to the ethernet LAN cable. Wait 5 minutes and the top led on the satellite should turn on BLUE. Set up an IP address reservation for the 1st satellite. Continue to do the same thing for the 2nd satellite. Then follow up with your devices.
JoshBear wrote:
Hi
Any ideas? Thanks
