acvitanov
Dec 03, 2017Aspirant
Satellite won't connect - constant white pulse
I bought an Orbi with two satellites a week ago. Initially set it up, no issues and both satellites connected automatically. I then did the dreaded firmware update and now one of my satellites won't ...
DarrenM
Dec 05, 2017Sr. NETGEAR Moderator
Are you able to connect directly to a satellite via Ethernet cable then try going to 192.168.1.250 and see if you can log into the unit and make sure its on the latest FW.
DarrenM
- acvitanovDec 06, 2017Aspirant
Thanks for the suggestion, but unfortunately it does not connect to the satellite even through a wired connection. The laptop doesn't appear to establish any kind of connection with the unit at all.
- DarrenMDec 06, 2017Sr. NETGEAR Moderator
At this point you will want to contact support they will be able to help with the issue or replace the unit if needed.
http://www.netgear.com/support/contact.aspx
DarrenM
