Garethaowen
Jul 14, 2017Aspirant
Satellite won't connect after router firmware upgrade
After some help. My satellite uint (rbs50) will not connect to my main unit (rbr50) after I stupidly upgraded the router firmware. Any idea how I can fix this?
- Jul 14, 2017
First try restarting the satellite. If that doesn't work then just do a factory reset of the whole system and the main unit should find the satellite if it's close enough.
Landerx
Jul 14, 2017Apprentice
Garethaowen
Jul 17, 2017Aspirant
Hi, thanks for your reply. I tried restarting (several times!) and resetting the Satellite no joy. Was just gearing up to reset the whole lot this morning, plugged it all in and low-and behold the damn this just connected! There's 3 hours of my life i'll never get back.
Thanks for your respone though.
- LanderxJul 17, 2017Apprentice
Glad it finally connected for you. It should now stay connected so it should be okay. Good luck.
