Garethaowen's avatar
Garethaowen
Satellite won't connect after router firmware upgrade
After some help. My satellite uint (rbs50) will not connect to my main unit (rbr50) after I stupidly upgraded the router firmware. Any idea how I can fix this?
  • Landerx's avatar
    Jul 14, 2017
    First try restarting the satellite. If that doesn't work then just do a factory reset of the whole system and the main unit should find the satellite if it's close enough.
