fmalloy's avatar
fmalloy
Luminary
May 27, 2020
Satellite/Router Connection Algorithm
How does Orbi assign WI-Fi clients to satelites/router?
I have 2 satellites (downstairs) and a router (upstairs). My smartphone is quite close to Satellite 2, yet it's connected to the router upstairs, further away. I get Good connection status for both satellites. I'm guessing that physical proximity isn't the consideration...?
Should I care?
  • Distance is a factor. Be aware that Orbi doesn't tell devices where to connect. It helps them get connected, however it's the device themselves that pick and choose which signal source and frequency to connect too based on there design, noise, signal quality and strength and environment.
  • FURRYe38's avatar
      • CrimpOn's avatar
        CrimpOn
        Is "Fast Roaming" enabled on the Orbi Advanced Tab, Advanced Settings, Wireless Settings?
