ekhalil
Sep 22, 2018Master
Satellites add 2 ms latency
I see that when measuring speed while connecting to a satellite there is -almost always- additional 2ms of latency compared to when connected to the router. Is this normal?
st_shaw
Sep 22, 2018Master
You don't state what points you are measuring the latency between. You also don't state whether you are connecting via wired or WiFi. However, if you connect to the Internet via the satellite you are going through the wireless backhaul. If you add an additional wireless link (the backhaul) then you should expect some additional delay. Two milliseconds is negligible.
ekhalil
Sep 22, 2018Master
I’m measuring latency between a device connected via wifi to a satellite and internet.
I have audio issues in VoIP calls using Skype for Business, which I never had issues with before Orbi!
Latency is an important factor in VoIP calls. I was measuring latency to see if it’s the issue or some other factors like packet loss. Any idea?
