ChinoMorales
Mar 01, 2020Tutor
Satellites and wall plug in
God day to all, I would like to know if it’s possible to connect 3 satellites and also add a wall plug-in to my router, I’ve heard that only 3 satellites per router are allowed. Thanks a lot in adva...
imalckydog
Mar 02, 2020Aspirant
I have the AC2200 Orbi Router and satellite installed, want to add an additional satellite...when I added the 2nd..my wifi speed slowed down to near nothing....without the additional satellite, my wifi speed is d/load 225 and upload is @ 11. What could cause the downgrade in speed with additional satellite?
Thanks
Mar 02, 2020Guru - Experienced User
FW versions same across RBR and RBSs?
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
What was the reason for adding a 2nd RBS?
imalckydog wrote:I have the AC2200 Orbi Router and satellite installed, want to add an additional satellite...when I added the 2nd..my wifi speed slowed down to near nothing....without the additional satellite, my wifi speed is d/load 225 and upload is @ 11. What could cause the downgrade in speed with additional satellite?
Thanks
