pmatern
May 30, 2020Aspirant
Satellites connected, devices see "full" wifi, but no internet connectivity through satellites
Updated from a TPlink router with extender, because we got tired of having to switch wifi networks when we went to the other side of the house. I was given an RBR40 router with two RBW30 satelli...
May 30, 2020Guru - Experienced User
1. What firmware is on the router?
2. firmware on the satellites?
3. What modem are you connected to?
4. How far from the router is the satellites? 30ft minimum is needed.
5. Have you tried resetting and re-installing the satellites?
pmatern
RBR40 Router Firmware V2.3.5.32
RBW30 Satellites Firmware V2.3.0.4
Modem: TP-Link TC-7610
Have tried resetting and restarting the router and satellites multiple times.
The 1st satellite is just about 26 feet direct line from router but passing through a wall/ceiling (if we moved it further away it turns amber and has trouble connecting to router consistently). The second satellite is about 30 feet direct line from next satellite passing through 2 walls.
SEE FLOORPLAN IMAGE
Both satellites show green connectivity almost all the time in the network map, but never show any devices connected to them. Devices well beyond the range of the router appear to have full wifi signal, but there is no internet connectivity and they don't seem to connect to the satellites.
- plemansMay 30, 2020Guru - Experienced User
1. update your firmware. all your devices firmware is out of date. rbw30 is on 2.5.0.2. rbr40 is on 2.5.1.16
2. what material is your home made of?
