Elvisj
Feb 11, 2017Star
Satellites do not connect
I have 4 satellites. All. 4 show in device list and all went through proper light sequence during install. But dashboard shows only 2 are connected. So when I select add a satellite, it shows the 2 a...
DarrenM
Feb 13, 2017Sr. NETGEAR Moderator
Hello Elvisj
You may want to try and power off the units that are already connected and then try to sync the other ones.
https://kb.netgear.com/31017/How-do-I-set-up-my-Orbi-router-and-satellite?cid=wmt_netgear_organic
DarrenM
