BrianNeedsHelp
Oct 24, 2017Tutor
Satellites do not seem to show correctly in Attached Devices
I have the Orbi with 2 satellites. Firmware 2.0.0.74 My issue is that both satellites show up in "connected devices" area as 2.4G devices, but do not show up in the "connected satellites" devi...
- Oct 27, 2017
After performing factory reset on Orbi (RBR50), the system went through a complete setup, and both satellites (RBS50) had entirely out-of-date firmware. Updated the firmware on those units, and now everything is working as I excpect.
DarrenM
Oct 26, 2017Sr. NETGEAR Moderator
You may want to factory reset the satellites and resync them again you should be able to connect to there IP address to access the firmware update.
DarrenM
- BrianNeedsHelpOct 26, 2017Tutor
Performed factory reset on satellites, but still cannot access them via their assigned IP addresses.
First thing in the morning, I'll try factory reset on the main router.
- BrianNeedsHelpOct 27, 2017Tutor
