rspam11
Jul 28, 2017Aspirant
Satellites have disappeared after auto update to 1.12.0.8
Hello My satelletites seem to have disappeqared. the main router (RBR50) admin page says iti is on 1.12.0.8 I saw an article that down grading to 1.11 may help, but i cant reach the satel...
- Jul 31, 2017Thank you for all the replies. I found another thread recommending a factory reset of the satellites followed by a factory reset of the main router. That seems to have addressed the issue except I had to manually redo all my configuration customizations. I sincerely hope I do not have to repeat this every time firmware is updated. It is extremely painful.
DarrenM
Jul 31, 2017Sr. NETGEAR Moderator
Hello rspam11
You can not disable auto updates. Are you able to access the satellites by going to there ip address? try typing 192.168.1.x where x= 2-10 and see if one of those ip address brings up the satellite.
DarrenM
- gbjacksonJul 31, 2017Apprentice
This is the same issue that has generated a 312 (and counting) comment thread relating to the firmware upgrade. To date, I don't think it's even been acknowledged by Netgear to be an issue....
