jaspolar
Apr 13, 2020Tutor
Satellites having trouble staying connected after splitting WL and WLA SSID's on RBR50
Wanted to maximize output of my devices by ensuring that devices could connect to 2.4g or 5g. I made the change earlier by enabling telnet, and then changing the SSIDs on my Orbi system with the f...
CrimpOn
Apr 13, 2020Guru - Experienced User
As no one has responded for some time, I think perhaps that it would be helpful to provide more background about the situation.
- What is the problem that setting SSID's is supposed to address?
- Satellites connect to the router over a 5G "backhaul" channel that is separate from the "user facing" 2.4G and 5G channels.
jaspolar
Apr 14, 2020Tutor
Well, it just seems that after I split the SSID's, one of the satellites wouldn't stay connected. All 3 rooms on the top floor are in a row, with satellite on one end, router on the other. The other satellite is in a room directly underneath the middle room. Essentially it's an inverted triangle. No device is more than 30 feet from each other, but when I split the SSID, at least one of the devices (the one on the bottom floor) kept dropping on the network map. It seemed like their communication was interrupted. A simple SSID split shouldn't cause that, unless there is more to the architecture than I'm aware. I work cloud infrastructure IT, but not hardware.
There has not been issues since I switched it back yesterday. Some devices just don't seem to have good connection at times. Primarly, the most important would be trying to cast a Zoom meeting on a firestick from an Android Note10 in the living room. I know the device is 5g compatible, and I wanted to ensure they had high bandwidth. Again, that device would be no more than 30 feet from the router.
