deltaboy
Dec 02, 2019Aspirant
Satellites keep disconnecting after reboot
So far, this product has been terrible. Out of the box, everything works great. But when I change settings (mainly reserve IPs) and the system reboots, the two satellites flicker in between blue and m...
deltaboy
our home was built in 2010, its not old by any means! just so many dead spots that really cripple the network
Dec 03, 2019Guru - Experienced User
What is the layout of your home?
You might try a 50 series Orbi instead of a 20 series.
- deltaboyDec 03, 2019AspirantOpen concept, 1200 sqft per level.
I may just reroute my router to the garage at one corner opposite my family room, so I can add a satellite and hardwire the AppleTV. This configuration will place the main router directly below the office too. - FURRYe38Dec 03, 2019Guru - Experienced User
Be sure that there is 30 feet in between the RBR and RBS or approximately in that range to begin with.
Try swapping RBS locations to see if the problem follows or not.
