HCC202's avatar
HCC202
Star
Oct 31, 2018
Satellites keep dropping off line
My system has been stable for several months now all of sudden I keep dropping the satellites. My system is RBR 50 and my firmware is 2.2.1.210
1 Reply
  • FURRYe38's avatar
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
    If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
    https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-and-connection-problems-Skybell/m-p/1649275/highlight/true#M43001
