williescout
Sep 28, 2020Follower
Satellites stuck on config sync
With RBR50 in AP mode 3 of 4 satellites are stuck in config sync backhaul status. My ISP is Comcast/xFinity and I'm using their gateway. It's worked fine in the past. The one satellite that connec...
Sep 28, 2020Guru - Experienced User
Try a factory reset on the RBS and RBR. Setup the RBR first in router mode. Don't connect the RBS. Configure the RBR for AP mode and get it setup with the host router. I use a static IP address on my RBR50. v70 and 192.168.#.50. Once the RBR is set up and tested to have internet services. Turn ON The RBS and I used the sync button in back and use the sync button on the RBRs add satellite web page. Had the RBS in the same room to let it sync. I have it about 5 minutes to settle in. I did see config sync once however upon doing a refresh on the RBRs web page, it showed connected on wireless.
