tucsontico
Feb 09, 2020Virtuoso
Satellites won't display device name after update to FW 2.5.1.8.
Had a power outage which required me to reset all my IOT devices, etc. Decided it would be good time to update FW to 2.5.18 from 2.3.5.30. Went smoothly without factory reset. Good speeds and connect...
Feb 09, 2020Guru - Experienced User
Not using a separated SSID name are you?
Happen in a different browser?
Diasy Chain enabled or disabled?
You may need a factory reset. Some don't, some do.
tucsontico
1) Never used a separate SSID.
2) Yep. Happens in Safari, Chrome & Firefox
3) Daisy Chain is enabled due to my setup. 2nd satellite is in attached garage requiring daisy chain.
