beckss1
Dec 14, 2018Tutor
SATTELITE DROP-OUT
Hi,
Last day I have a problem with my ORBI system (RBR40 - V2.2.1.210 and RBW30 - V2.2.1.204) and all attempts for resolving not help me
I mean reset sattelite and re-add it again help me for not...
beckss1
Dec 15, 2018Tutor
Thanks for providing quick answer, but only after that I downgrade sattelite version to V2.1.4.16_1.0.17 it started to work properly without any discoonect issues.
Thanks and regards,
Dec 16, 2018Guru - Experienced User
Glad you got it working,
Try the suggestions next time if you upgrade to 210. v210 is working for others.
Enjoy.
- beckss1Dec 16, 2018TutorThank you for replying.
I checked via GUI and via mobile application, that satellite indicate me available update and after downgrade version I not disable automatic upgrade it made this (I mean came back to latest version) . From last Friday when I open ticket satellite work without drop out. Then probably this is solution for this issue.
Thanks and regards.- FURRYe38Dec 17, 2018Guru - Experienced User
Enjoy. :smileywink:
