beckss1
Dec 15, 2018Tutor
SATTELITE DROP-OUT
Hi,
Last day I have a problem with my ORBI system (RBR40 - V2.2.1.210 and RBW30 - V2.2.1.204) and all attempts for resolving not help me
I mean reset sattelite and re-add it again help me for not...
Dec 16, 2018Guru - Experienced User
Glad you got it working,
Try the suggestions next time if you upgrade to 210. v210 is working for others.
Enjoy.
beckss1
Dec 17, 2018Tutor
Thank you for replying.
I checked via GUI and via mobile application, that satellite indicate me available update and after downgrade version I not disable automatic upgrade it made this (I mean came back to latest version) . From last Friday when I open ticket satellite work without drop out. Then probably this is solution for this issue.
Thanks and regards.
Thanks and regards.
- FURRYe38Dec 17, 2018Guru - Experienced User
Enjoy. :smileywink:
