OrbiWANKenobi
Sep 01, 2017Star
Scary warning: 40 Mhz and 20 Mhz coexistence?
So I use my Mac's Wireless Diagnostics WiFi scanner tool to find the best 2.4G and 5G wifi channles to use, then enter my two selected channels into the Wireless Settings page of the Netgear Orbi web...
- Sep 01, 2017
hi , the 2.4 gig wifi world is saturated with users and so as to ensure that this doesnt continue to happen the wifi alliance set a rule that forces the 2.4 gig down to 20mhz in areas where the 2.4 gig is congested and to avoid further congestion , its also called neighbor friendly wifi
so if you disable this setting and force it to run at 40mhz you are just being rude to your neighbors and pretty much giving them the bird
so you can be nice and leave it enabled and everyone will get a bit of bandwidth without too much congestion or you can be a prick and disable it and say screw you to your neighbors
thats your choice
your older 2.4 gig devices will work regardless of if its running at 20mhz or 40mhz
here is a link to help you understand why its there and what it does
http://www.nxp.com/docs/en/application-note/AN5185.pdf
peteytesting
Sep 01, 2017Hero
thats your choice
Mayhugh1
Feb 09, 2018Apprentice
wrote:hi , the 2.4 gig wifi world is saturated with users and so as to ensure that this doesnt continue to happen the wifi alliance set a rule that forces the 2.4 gig down to 20mhz in areas where the 2.4 gig is congested and to avoid further congestion , its also called neighbor friendly wifi
so you can be nice and leave it enabled and everyone will get a bit of bandwidth without too much congestion or you can be a **bleep** and disable it and say screw you to your neighbors
thats your choice
There should be an faq section with explanations about the effects of various settings with the same level of clarity as the one above. Many settings are left up to the user to 'play with' and according to Darren many of them could solve problems some users are having. An explanation of the options on the debug page is also needed. Details about how the backhaul orks would also be helpful and help the users more intelligently troubleshoot their systems.
- INTOTHEWILDApr 02, 2018InitiateCan someone explain what this means in laymans terms? Also, some of my devices do not support 5G but I want the ones that do support it to use it obviously, but when I set my laptop and iPhone to use 5G my netgear apps no longer show the devices on the 2G network and I lose wifi access to the printers that use 2G. Is there a fix for this?
- FURRYe38Apr 02, 2018Guru - Experienced User
What model system do you have and FW are you using?
