ed1968
Nov 19, 2020Tutor
Scheduling Firmware Update on RBR50/RBS50
Hi Everyone, I am comtemplating scheduling firmware updates on my router/satellite. Couple of questions: 1) is this a good idea? normally I like to supervise an update and unattended scares me a ...
Nov 19, 2020Guru - Experienced User
ed1968 wrote:Hi Everyone,
1) is this a good idea? normally I like to supervise an update and unattended scares me a bit. No.
2) do I accomplish this via the Scheduler in >>>Advanced>>Security>Schedule by unblocking the time for it to occur ie. 0100-0400hrs?
FW updates can't be scheduled.
ed1968
Nov 19, 2020Tutor
I was informed by Netgear that they typically push out new firmware updates between 0100-0400hrs. If you block services via the Scheduler on certain days/times you should be limit when the updates to firmware will be installed.
Am I seeing it correctly?
