SLK-Purdue's avatar
SLK-Purdue
Luminary
Mar 14, 2020
Script to load /etc/hosts, Static DHCP registrations, and Device name etc
I have developed a script to load /etc/hosts, set static DHCP reservations and update device name, and device type from a master excel spreadsheet.   The script works well to create /etc/hosts and sets all the DHCP registrations.   Items set are:
       config set reservations[xx}
       nvram set orbi_dev_name[xx]
       nvram set orbi_dev_name_v2_ntgr[xx]
       nvram set orbi_dev_name_ntgr[xx]
       nvram set orbi_dev_type_ntgr[xx]
and then nvram commit and config commit.   Finish with a reboot.
Updated device information is not showing on the web ui.   If I edit the information on the web ui, nothing changes in nvram.   Clearly, I am missing something.
The secret sauce appears to be in the net-cgi program that populated the device structure used in the web page display. (see DEV_show_device.htm and DEV_device_info.htm).  Information is being saved somewhere else.  Any ideas how to set the appropriate information in a script?
Thanks,   Scott
  • CrimpOn's avatar
    CrimpOn
    My practice was similar to yours except:
    Everything was "config set".  Nothing was "nvram set".
    Reservation does not have an "s".
    I opened the web page "Attached Devices", saw that everything was populated, and then clicked "Apply".  Did not do a reboot.
    • SLK-Purdue's avatar
      SLK-Purdue
      Luminary
      You are corrrect on "reservations[xx}.  My typo.   My information didn't populate.
      Scott
        SLK-Purdue
        Luminary
        Just to clarify, Static DCHP reservations are populating and working fine.  My problem is with the device name, model, and type.
  • Where do you change in the web ui and you don't see the changes on nvram? If I -for example- go to Attached Devices on the web ui and change the Device Name of a device I will see the changes directly on the parameter orbi_dev_namexx of that specific device.
    It will be interesting if you can share the script that you are using.
    SLK-Purdue wrote:
    Updated device information is not showing on the web ui.   If I edit the information on the web ui, nothing changes in nvram.   ......
      SLK-Purdue
      Luminary
      Here is an example:
      Telnet ooutput
         root@Ksander-ORBI:/# nvram show | grep -i A4:D5:78:13:69:7C
         reservation76=192.168.1.210 A4:D5:78:13:69:7C sense
         orbi_dev_name_v2_ntgr76=A4:D5:78:13:69:7C 17 Sense
         access_control25=0 A4:D5:78:13:69:7C 1 65523 SENSE-M725000917 0 0
         orbi_dev_name_ntgr76=A4:D5:78:13:69:7C 26 Sense
         orbi_dev_type_ntgr76=A4:D5:78:13:69:7C 1 1
         orbi_dev_name76=A4:D5:78:13:69:7C Sense
      Web Page shows:
      IP Address 192.168.1.210
      MAC Address A4:D5:78:13:69:7C
      Device Model ---
      Device Name SENSE-M725000917
      After I change Device Model and Name to Test Model and Test Name in web ui, nvram does change to
         orbi_hid_mac=A4:D5:78:13:69:7C
         orbi_dev_name_v2_ntgr76=A4:D5:78:13:69:7C 11 Test Model
         access_control25=0 A4:D5:78:13:69:7C 1 24355 SENSE-M725000917 0 0
         orbi_dev_name_ntgr76=A4:D5:78:13:69:7C 24 Test Model
         orbi_dev_name76=A4:D5:78:13:69:7C Test Name
      but the change is only 1 way (web ui to nvram).   It I change nvram, commit, and/or reboot, the change is not reflected in the ui.   Changed nvram back:
      Web ui stays with Test Name
      Having other issue with device type but let's solve one problem at a time.
      If you are curious, Sense is a power line monitor.  Cool device if you are into cool IoT things.
      Thanks,
      Scott
      ps. happy to post the script if anyone interesting,  Basically export master Excel file to cvs.  Script run awk script on csv file.   Output /etc/hosts and a command file with config set and nvram set.   Finally edit dnsmasq.conf to read /etc/hosts, restarts dnsmasq and do the nvram and config commits.
      • ekhalil's avatar
        ekhalil
        Master
        After commit, you either need to go in the web ui to >> ADVANCED >> Setup >> LAN Setup and click on Apply, or you need to reboot the router for the changes to take effect.
        SLK-Purdue wrote:
        ............   It I change nvram, commit, and/or reboot, the change is not reflected in the ui.   ........
        Yes, I would love to see your script please. Thank you
