RaoulD
Dec 03, 2020Aspirant
Seagate NAS Personal Cloud 2-bay via ORBI not found
Hi All, Since I've moved to my new place I have not been able to access my files on the Seagate Nas anymore. I can see in the ORBI app that is is connected by wire, but furthermore I can't find o...
RaoulD
Dec 04, 2020Aspirant
Thank you for your reply CrimpOn
When I try to reset the Seagate NAS, the led indicator is non-stop red and it is not found in the orbi-app. When I turn it off and switch it back on, the led with be white flickering and my orbi app can detect it. The ORBI app indeed shows me the IP of the NAS.
I've tried the manual from Seagate. I've gave that up. I don't know where to look anymore. My provider router, my orbi system, the nas... I have no clue that's why this post.
What do you mean the fact that the ORBI is in AP mode. I actually never really thought this thru why I put it in AP mode. Should I be able to fix it when I put it in Router mode? Any other benefits? I am really not a network specialist or familiar on a detailed level.
schumaku
Dec 04, 2020Guru - Experienced User
Leave Orbi and your router alone - this is almost certainly a NAS issue.
RaoulD wrote:When I try to reset the Seagate NAS, the led indicator is non-stop red and it is not found in the orbi-app.
The Seagate Personal Cloud 2-Bay User Manual does not provide a lot of information for the red system LED, only on red flashing (where the link is pointing to), indeed.
RaoulD wrote:When I turn it off and switch it back on, the led with be white flickering and my orbi app can detect it. The ORBI app indeed shows me the IP of the NAS.
So not complete dead. It looks like the NAS does fetch an IP address - assuming from your local IP subnet. Please compare your computer LAN IP and the NAS IP - post and ask if unclear.
What happens if using http://[ip-addess] or https://[ip-addess] in a Web browser?
- RaoulDDec 04, 2020Aspirant
Hi schumaku thank you for your reply.
IP of my laptop which is wireless connected to ORBI: 192.168.178.123
Seagate NAS Wired: 192.168.178.59
Wow, I've tried to connect via HTTP://192.168.178.123 and it looked like it could reach the NAS. I was almost relieved! But the message is: "Your device might be powering on, Try again in a few minutes". The NAS has been on for days now, so it probably won't be a few minutes. I think it won't go further then this.
