cyberprashant's avatar
Nov 28, 2016
Seamless Roaming Orbi
So far impressed with the orbi system.   Satellite firmware update was glitchy using Chrome, but worked fine in IE.  I did update manually.      Seamless roaming appears to be happening.  You ca...
  • peteytesting's avatar
    Nov 28, 2016
    just to clear something up the orbi is NOT seamless roaming , it has band steering and ap steering but thats not technically seamless roaming
    the client device stiull disconnects from one transmission to then move to another
    real seamless roaming does not disconnect at all
