Retired_Member
Jul 07, 2017Seamless roaming whether offer another way to achieve
Hi guys, I own Orbi RBK40, but according to tech brochure, internal network link speed between router and satellite is 833Mbps, that's means even I connect via Ethernet cable it can't run as maximum ...
peteytesting
Jul 07, 2017Hero
Retired_Member wrote:
Hi guys, I own Orbi RBK40, but according to tech brochure, internal network link speed between router and satellite is 833Mbps, that's means even I connect via Ethernet cable it can't run as maximum speed 1000Mbps, right?
So, my question is if satellite connect router with Ethernet cable, and place both stellite and router far enough that has a little overlay, can Orbi system still roaming seamless?
Thx.
hi you wont find a domestic router that will do 1000Mbps
the orbi at this stage does not connect via ethernet from router to sat
however no matter the wan to lan is still limited and you wont see 1000Mbps over ethernet never mind wifi
