SamGreen
Jun 29, 2020Aspirant
Secure Network
While connected to the Orbi network, every website I try to go to and even on my cell phone, tells me it cannot connect do to the network not being secure. Whenever I disconnect from the Orbi network...
Jun 29, 2020Guru - Experienced User
If your connected to the Orbi system and have WPA2 and AES enabled then your connection to the Orbi IS secure.
What sites are you visiting? Some sites may not be using HTTPS://Address vs HTTP:// which causes some browser to report the site as not being secure. This would be a web site issue, not a Orbi or device problem.
