SamGreen
Jun 29, 2020Aspirant
Secure Network
While connected to the Orbi network, every website I try to go to and even on my cell phone, tells me it cannot connect do to the network not being secure. Whenever I disconnect from the Orbi network...
SamGreen
Every website says it unsecure, the only website I can go to is Google, but can't go to anything on Google. No website works when connect via Orbi, but everything is fine when connected via home network.
- FURRYe38Jun 29, 2020Guru - Experienced User
So is Orbi on your home network do you have a differnt wifi system at home along with Orbi?
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?Do you have Armor or Disney Circle feature apps enabled on Orbi?
- SamGreenJun 29, 2020Aspirant
I already had my home network. I added Orbi because I couldn't get a stronge enough signal upstairs and I was told Orbi would solve this. However the Orbi is useless becaause I can't connect to any website because it says the connection is not secure. Therefore, I have to disconnect from Orbi every time and connect to my original network.
So please answer the following:
What Orbi model system do you have?
How is Orbi connected to your home system?
What is your home network system comprised of?
- SamGreenJul 06, 2020Aspirant
Home network is connected via internet supplied Netgear N300 WIFI Cable Modem Router Model C3000
- FURRYe38Jul 06, 2020Guru - Experienced User
This is a modem with built in router and wifi. Is this modem using the router and wifi or is the modem in modem only mode?
